08.11.2009, 05:24 PM
Front wheels ballooning on a vehicle is caused by the center diff sending most of the power to the front- thick fluid required in the CD.
The outside wheel ballooning when turning a corner is due to the fluid in the diffs being too thin, thicker fluid also required.
Taping the inside of the tires will help to reduce ballooning, as will using a thicker tyre.
