08.14.2009, 03:20 PM
Originally Posted by kwik View Post
pedebasher... do whatever floats ya boat... sorry, i had to say that :P
how is it powerd? padels? and i asume your going to have a rudder right?
good luck on the project, and get some pics up after, would be great to see this... and maybe the "skin" could also be something recycles... thin aluminum maybe or some plastic sheet from something....
Some giant heat shrink would be cool! I agree with using a recycled product. Used be called "being cheap", now it is called "green"...
I am building a storage shed at my shop right now. Dimensions will be 10x21. Odd size, but I had a tarp canopy frame (separate tubes that slip fit together) that was not being used. Decided to weld that up and add some bracing (more tubes that I had). My buddy pulled up a deck, and gave me the old lumber, 60+ 2x6x12' treated boards. My other friend gave me some old thick wall 3" water pipe, I cut that down and concreted 12 3' pieces in the ground for supports. Bolted some of the lumber to the pipes and used the rest to make a "deck". Flipped the old boards over so the good side faces up, looks like new! Another friend frames houses, so he gave me most of the scraps from the last house, I almost have enough to frame the walls, then i will bolt the canopy top to them and use some old sheet metal siding (came off my building during the storm) as the roof. So far i have about 150 bucks in it, mainly nails, bolts, and saw blades. I consider this being cheap!!! but I would rather not spend my money, and used lumber is just as good to me. I priced new lumber/materials and would easily go over 2 grand....
