Thread: OFNA Mutilator
Jammin CR Mount with Mutilator does not work
Jesse M
Jesse M's Avatar
Jammin CR Mount with Mutilator does not work - 08.14.2009, 04:05 PM
Just got the CR motor mount at RCM and it seems as though it does not work with the Mutilator. Even if I got the Jammin CR buggy center diff braces, which you need to mount the RCM mount to the chassis unless you have some sort of 1/4'' spacer, the Mutilator spur gear would still hover over the top of the RCM mount by about 5mm so you would not be able to mount the center diff plate. Then a spacer for the RCM mount and the front diff mount would be needed to clear the 62 tooth spur gear. I would also need to dremel the bottom of the chassis to allow the spur gear to fit since its being lowered about 1/4'' from its stock position.
Any help is appreciated, especially documented visual footage of the conversion.
I almost feel like getting the CRT mount and rigging it up somehow because the CRT X1 also uses a 62 tooth spur gear I believe, so clearance top and bottom wouldn't be an issue. I may post pics later of the attempted conversion to show incompatabilities.
