08.15.2009, 12:34 AM
are you running a fan on the heatsink? on the mm it is needed, just a small 25mm 12v fan is the best, hook it right up on the power leads, also drilling holes in the bottom case helps alot to
I dont run a fan on the mamba only a caps for the motor I tried with a heatsink also still same problems... the mamba max have already hole drilled on in the bottom case...
