NovakTwo
Senior Strategist
08.16.2009, 01:56 PM
We need to update the timing info for the Ballistics. At this time, I suggest sending an email to tech@teamnovak.com
Here is what Steve posted elsewhere---it does not address your specific question:
Actually the timing does come "pre-set" exactly like the timing on the SS line of motors.
While there is no physical stop preventing you from adding more timing, the timing label itself only has deliniations going so high or so low. We recommend using timing settings only within the range delinated by the label.
Originally Posted by gixxer View Post
I just got mine this week. Question on the timing though. How many degrees is each line? There are 3 pos and 3 neg. Does it go to 12 degrees like most motors, making each line 4 degrees?
thanks
Novak Electronics, Inc.
