Thread: My new truggy
Semi Pro
Semi Pro's Avatar
08.16.2009, 08:09 PM
Originally Posted by Jesse M View Post
Very Nice.
Do you know if that motor mount would work on an Ofna Mutilator? (62 tooth) I've tried the RCM Jammin CR mount that is supposed to be compatible with the Mutilator, but it doesn't really work unless you modify a couple things. The spur gear on the Mutilator is just too big for the mount. I'm running be running either a CC 2200 or Medusa 70mm 2300.
Any help is much obliged.
like i told you before jessie m , you need to run a smaller spur, like the kyosho 46t for the cr motor mount to work
there isnt any kit out their that is going to work with the stock 62t gear
