zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.17.2009, 01:57 AM
Originally Posted by BUSAFIED View Post
zp -i haven't found any regs...but i'm curious to see if there are any. I certainly haven't found any in the ROAR rulebook.
and full triple or quad? I thought it was best to keep airtime down. I mean, I'll give it a shot, but I was under the impression that the less time in the air meant more speed around the track.
Well, I guess I spoke to much, i know taking the triple in one go is much faster than taking the first double and then the third after. My track does not have a quad, but I would think it would be faster taking the whole thing if you can get enough speed, because you obviously have higher entry speed, which to me would equate to moving through the jumps faster overall. But I have no experience on quads.
You are running 3s packs, IIRC?
I just thought, we should make a single thread and post our results on it after the race sunday? Although I won't be home until monday, or tuesday.
I am hoping for a podium finish this time, as last time I had BEC troubles and caused me to fall from 2nd (hot on 1st) to a 4th place finish. I had the second single fastest lap time as well.
Good luck man! Wish me luck!
