Ryu James
Ryu James's Avatar
08.18.2009, 01:59 PM
Originally Posted by KaztheMinotaur View Post
I had to do some dremel sanding to get the hub to fit into the milled out area after the hardening? Wonder if the gear would have changed size slightly ? Or maybe it was a buildup of oil bakes on gunk ?
i bet it was due to buildup of the hardened coating.
my machinist made a mistake on my motor mount plates so he is making new ones today. i hope to get my motor mounted up tonight.
hey kaz,
after you heated the gear and dropped in oil did you then heat again and drop in water? didnt someone here on the forum say to do it that way? or is that necessary?
Jammin SCRT10 Neu 1512 1y
