08.18.2009, 04:53 PM
I like how they "recommend" swapping out both at the same time. The ratios are different from 9/29 to 13/43. Not a huge difference but this truck does not have a center diff, so one set of tires will turn fast than the others... 3.22 vs 3.31.
I do agree that bulkhead flexing is a big issue. Either the flm or gh bulks would cure that. I will probably get a pair of these diffs for my 5th scale savage build, along with the al bulks it should help with the extra weight... Hopefully!
