dave_mackinnon
08.19.2009, 10:10 AM
Shaun.. You can't force current from a car battery.. It's a constant voltage source..
If you want to 'help' a LiPo pop, find a bug battery charger and set a 10A charge rate and hook that up to the battery... that should be more entertaining.. My guess, without trying, is that it should see 20+ volts...
You could also plug it into the wall...
