Kajman
Kajman's Avatar
08.20.2009, 12:38 PM
Originally Posted by BLBuggyBoy View Post
lower kv and higher voltage= lower temps due to less amp draw and amps is the amount of electricity flowing, voltage is just the "pressure" behind the electricity, im using the old water hose analogy lmao im a electrical engineering major what can i say lmao
yeah, but having the same voltage (I 21v as I will not change batteries) when we use low kV motor with harder gearing and high kV motor with lighter gearing you will get similiar motor temps...
