Ryu James
Ryu James's Avatar
08.21.2009, 06:09 PM
Dwight is obviously on the right track to hitting the 100mph mark. Follow what he is doing and pic his brain as much as you can, sharkattack.
Also Shark, if you want to avoid doing the 8s or 10s setup stick with the MMM, 6s lipo, and get a 1521 or 1527 Neu motor. there are a bunch available right now on offshoreelectrics.com great prices too. if you run 6s just choose a motor with about 2000kv. this will put your motor in the 50k rpm range which is close to max of the motor but not so fast to damage your motor. if you choose this type of setup the rest is gonna be up to gearing and aerodynamics and durability really. good luck.
Jammin SCRT10 Neu 1512 1y
