mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
08.23.2009, 11:42 PM
Doing this will help in stiffening the motor plate by securing the bottom of the motor mount with a screw in the round plastic part the mount pivots on. When adjusting the gear mesh, that bottom screw needs to be loosened same as the top one. I have modified that round plastic part further more by installing brass inserts so that I can now really screw the motor mount very tight against the motor plate.
No brain, no headaches.
