08.24.2009, 04:45 PM
Mike is having a great sale on Polyquest li-po's at the moment. Are you running a single battery or dual?
If you are running a single or dual set up, ...the PQ or the Hyperion G3 line is excellent. Your 9xl is not the best quality motor so you will have to pay close attention to temps.
Hard to believe that you still have a v1 mmm esc. You can send it in for a free upgrade if you wish.
If you are running a single batt set up, go w/ a 30c rated battery..such as the ones I mentioned above. If you go w/a dual set up, you can go for a lower c rated battery...20c seeing as you are pulling from 2 batts. instead of one.
Actually, I would spend the money on the ccneu 2200kv motor and a battery...even if it means only getting 1 batt. The ccneu motor on 5s would do well in your Revo and run cool and it is a much, much, much better motor than the 9xl you have.
