08.24.2009, 07:34 PM
Originally Posted by loa View Post
Why not two 5000mAh?
Well add tx and shipping (and probably duties since I'm in Canada) and you quickly get to 200$... :-)
Loa
First, I did not notice you were form Canada so you are correct on the $200-.
If you are running 2 batts. in parallel, you could get, as mentioned above, 2 5s 3000 mah for a 5s 6k set up. One advantage is that the lower mah. batts. are cheaper than say a 5k batt.
