Originally Posted by KaztheMinotaur
The 40T spur requires grinding of the top plate...chassis fits fine though.
I had to slot the motor mount for the front drive shaft...now it isn't pretty anymore...
yeah the stock top plate has to be opened up a bit to fit over the 40t spur. its good though that slotting the mount at least worked. it should be strong still with as wide as the base is of that mount.
