Originally Posted by sharkattack99
oh for got to ask what is a pistix? and why would i need one?
it's an adapter that makes it possible to use aircraft escs like the phoenix hv 110 that can handle much more voltage.
basically, the pistix translates the throttle signal of an aircraft (which is different from a land esc) to a land signal. you need to use manual servo brakes though as an air brake translation gives little more than the feeling of a drag brake.
