08.27.2009, 09:47 AM
I just made more or less the same conversion, but on an Aftershock. I am also using the TD motormount, but still the 2 speed stock gearing, which is 63 spur and 25 pinion. I havenīt fully tested it, but seems to run pretty good.
What will I need to run single gear. Is it only the single speed hub from TD?
