MetalMan
MetalMan's Avatar
08.27.2009, 12:14 PM
What if you set the mechanical brakes to lock at a higher brake input, so if you needed reverse you could just push the trigger slightly forward? You wouldn't get a lot of speed in reverse, but it could be enough to turn you around.
