KaztheMinotaur
KaztheMinotaur's Avatar
08.27.2009, 08:09 PM
You got that to encase the cable in instead of the tubing that came with the brakes?
I discovered that you don't need to make a new front plate...just flip the stock one over.
The shorter brake rod will have to be cut down a lot. I'm also going to flip the brake servo around to the output shaft wil be to the rear.
