Ryu James
Ryu James's Avatar
08.28.2009, 07:26 AM
yeah i had considered doing that but because the plate is countersunk on one side i wanted to make my own part.
anyway, i had a question for you. have you ever ran baja wheels and tires? if so, how do they compare to the stock ramp set and how much was speed affected due to the smaller size?
i am contemplating getting some baja wheels and tires just because then i have more options but they look small on the ramp after seeing the stock ones on. plus, if i run baja wheels then i dont have to make new brake discs and can just use the 24mm discs the integy set came with. not sure what i will do yet. wanted some input.
Jammin SCRT10 Neu 1512 1y
