gixxer
gixxer's Avatar
08.28.2009, 08:59 AM
What use would a replaceable stator be anyway? I mean, if you remove the stator (and already remove the ends and rotor), you are left with just a cyclindrical shell. I can't imagine the replacement cost of the stator/shell is much more that just a stator...
BrianG if you look at novaks new series it will all make sense. Basically if you were doing a spec class you buy one motor and then just buy a wound stator for the other turns you want. That way you spend about $30 for each different turn instead of $90 a pop for each turn you might need.
http://www.shopatron.com/products/pr...56.56692.0.0.0
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
