zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.30.2009, 01:21 AM
beauty, thanks for posting Sike.
I would run 6s, so the 330 Kv. of the scorpion motor would equate to 45mph, not too much faster than the 40mph it's geared for at my track, which is perfect. (we have a long straight section)
If they have a 300Kv., that would be ideal, but they have a big gap in their Kv's to choose from.
I was also thinking about a truggy center diff, but the Revo diffs are too high of a ratio to be used with one, you would need hybrid diffs.
Q1: What diffs were you using to blow the bearings? And how would an inrunner/trans setup be any different in that respect?
Q2: Simply, what do you think of the motor in question? Think it will be suitable?
If this did work, then the handling on the truck would be in short, sick. I would be able to keep up with truggies no problem, as I can keep up to most of them even with the high CG as it is now.
