Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
08.30.2009, 01:24 AM
Originally Posted by Rivermaxx View Post
Hey Chad, I dont think you can put that ti-ni coating on aluminum, only steel but I could be wrong. Plus I have never seen one. As far as Ultramaxx gen III gears the idlers are made out of the same bronse alloy that was used in the otb gears input gear. I am almost positive the 1st and second gen Ultramaxx gears had the same issues with wear thats why there is 3 generations, the latest is the greatest and almost impossible too find.
You know what, I think you are right about not being able to coat aluminum with titanium-nitride.
Yea, the GenIII Ultramaxx gears were actually part OTB, which is why they were so bad-ass and so expensive. For some reason, the special bronze and aluminum gears can be run against each other with no problems, which is why the OTB gear-sets were so successful! Aluminum against aluminum is bad news, and acts like sandpaper rubbing against skin...nothing lasts. Even aluminum against steel wears very quickly, as Neil found out.
Anyway, if you can't find the Ultramaxx GenIII set, your best best is to run the stock steel input gear, UE/RCM/RRP steel idler gear, and the stock nylon output gear. With proper slipper settings, that transmission setup will last a long time.
I almost bought a NIP Ultramaxx GenIII gear-set not too long ago, for just $175 shipped, but at the time I didn't need it and had no clue how much it was worth.
-Chad
PM ME IF YOU HAVE THE BELOW:
