lutach
lutach's Avatar
08.30.2009, 07:47 PM
Originally Posted by littlegiant View Post
OK now that I know this, i feel worried about my MM and HW150A. So are sensored esc with sensored motors safe from this problem?
Will smaller pinions help prevent sensorless escs from burning up when a truck is rolling backwards and u give it a little throttle?
Speed controls are made different. Some will have a different firing sequence. Sensored ESC should not have an issue locating the rotor. A smaller pinion will lessen the load on the motor, but anything can cause a ESC (Or motor) to fail. If you have a ESC that offers a setting to completely brake before going forward, this should not be a problem and I know the Castle car controllers has this options.
