Rivermaxx
08.30.2009, 10:28 PM
Dwight have you tried those kershaw plastic pinion gears. Because I am not satisfied they will handle the torque. Bigger gears can handle more torque with out stripping because more teeth are engaged that why the bigger plastic spur usually hold up. I was also told by Nic case to use steel gears but maybe a mod 1 gear is alot tougher than a 32 pitch because of the thicker gears. You guys think a real neu 1515 1.5 d ,castle neu 1515 1y or 2 castle 1512 1y with 2 esc's on 6S each would be better in a slightly heavier gmaxx for high speed setup. Dwight didnt you have a twin brushless revo ?
