DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.31.2009, 12:28 AM
Originally Posted by Rivermaxx View Post
As far as going for broke I would like to keep my build on a budjet. I also would like to use an off the shelf castle mmm esc on 6s. As far as making high speed passes I only can get one good run in probably 1000' of space. So I really dont need to run multiple passes. I have UE 1/8 scale diffs and I am sure my g-maxx will weigh less than a brevo. As far as the twin 2200 turning the tranny to dust Thats why I was thinking of running 2 less torquey castle 2650 mmm combos. So running 2 systems on 6s will work then with no sync problems?. I assume you geared it too the sky right? I will put the titanium gears set I have in If I need too. So the drive train I am not worried about. Tires I am getting some custom made ones from bsr put on 23mm wheels hex wheels. I am going to do my initial testing with the 15151y first and then step up to what will work.
there won't be any sync problems. i tried both neu sets with no success on the 3905 stuff, but it didn't really suprise me. however, twin feigao 8XL's were good.
the twin brushless neu setup with the UE diffs should be fine. I geared mine 54/24 and then switched to mod 1 and went to 36/22 with the feigaos. Still, in the end it didn't make me much faster than a single neu although it still had loads of torque.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
