MetalMan
MetalMan's Avatar
08.31.2009, 02:30 AM
I thought it was balance lead first, then main battery lead? That's the way I do it. Also, make sure the LBA10 is in M (master) when used alone. If the red LED flashes very briefly, that means it doesn't detect the balance lead. Blinking green LED means it's in charge mode, as Brian mentioned.
Using 2x LBA10 can get a bit tricky, took me about half an hour to get it right.
