nitrostarter
nitrostarter's Avatar
08.31.2009, 01:45 PM
How big of gears do you guys want?
Go to sdp.si.com and go to "Buy Online". Click on the Metric Unit button. Then go down to the option for Gears. Then click on Spur Gears, next click on the suboption called "Metal". Then you should be able to adjust the search functions for 5mm bore and Mod1 specs and voila! Metal gears in Carbon steel, 2024 Aluminum alloy, 303 Stainless Steel. Teeth numbers available: 14,15,16,18,20,22,24,30,36,42,48,54,60,72,84,96.
N. Rustler conversion
