08.31.2009, 10:33 PM
A Wye wound motor isn't "far better" in efficiency, but it is much more "tunable" with timing adjustments, so Wye wound motors have more utility. You can effectively "go up a tooth or two" with timing on a Wye wound motor(increased timing increases kv much more on a wye wound motor).
