Originally Posted by revo guy
how would you perfectly center the hole in the output shaft?
I made a simple jig from a piece of 1/2'' X 1'' X 2'' steel. The jig has to be made very precisely, if you can make it with good precision then it will help you have perfectly centered holes in your shafts every time. I just put the output shaft in it, flush with the surface, tighten the set screw so the shaft doesn't move, I put the jig in a drill press vise much like
this one and drill in the hole of the jig which guides the drill bit.
