justpassedu
09.01.2009, 03:04 PM
Well I tested them real quick and the pin fell right out of two of the axles and are lost , i took some pin's from my slash and used those now , they are a tad shorter but the thickness is the same. I also found some little metal things that goa round the pin to hold them on. Put those on and they appear that they can fly off easily but for my test run they held. Initial impressions are there is too much slop and play between where the bearing is and the adapter. The front wheels wobble and the rears do a little bit also. Not sure how i can fix this ?? if anyone know's . Everyone is def. gonna love the increased ride height as i did . It actually felt a little faster also if that sounds weird at all , but the extra ride height was great , i can tell on the track though the wheels and tires or adapters are gonna break something so the play and slop needs a solution. This was only a 5 minute test up and down the street.
