gyn77
09.02.2009, 03:42 AM
what kind of motor temps do you see on the 1521 pushing that 7kg baja? and what is your gearing?
looks great by the way. just wanting to pick your brain to gain as much info as i can for projects i am doing/planning to do.
Neumotor 1521 got 67 C° at max after strong use on grass/dirty/stones and external temperature of about 30 C°.
My gearing is: spure gear 47, pinion gear 14 with center differential.
I want to see how it will get hot with bigger original baja tires.
