mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
09.02.2009, 10:23 AM
Originally Posted by revo guy View Post
So then for the 2.6mm would a 7/64 (2.78mm) work for the output shaft?
The real measurement of the hole for the spider gear pin in the shaft is 2.5 mm. I went with 2.6 because it gives me a little more play just in case the hole I made is off by a thousandth or two. If you have a way of making an absolute centered hole in the shaft you can use a 2.5 mm bit. If you're like me and your work is ''precise enough'' then I suggest a 2.6 mm. 7/64th or 2.78 mm is too big IMO, the pin will wobble in the shaft too much.
No brain, no headaches.
