09.02.2009, 03:07 PM
The screws are either 2.5mm or 2.6mm screws cut short 3-4mm as they will otherwise damage the windings of the motor.
You will need to get them from a outlet as they are not common - not here in the UK anyway. Same problem I have with Hitec metal geared servos
