R00ST
09.02.2009, 07:05 PM
Yes a bearing would probably work very well. I would check your local hobby store and see if they have something hopefully the same (or darn close) size to the axle diameter, and about 1.5-2mm thick.
The problem is pretty easy to fix on Jamie's end, just drill the axle holes further up the adapter.
Since it looks like the STE has a much larger gap depending on which truck he decides to market the adapters for, he can drill them for one truck and include shims so the opposite truck can run these out of the box as well.
