justpassedu
09.02.2009, 07:32 PM
what i have done so far today is add two washers in the front between the gap and there is no play and one in the rear witch still has some play , i will need to add one more in the rear if i can find a few laying around. I also just zip tied around the adapter where the pins go through the axle so they do not fall out. Not sure how this will hold up in the long run but a quick test run and it was running pretty good. The extra ground clearance is great , i just do not want it to break anything when i am out running it. Drilling the pin whole further back is def. a great idea. Do you guys think i will run into any problem's with the way i have went about this? i will try and get some pic's up as soon as i have a chance
