littlegiant
09.03.2009, 02:39 PM
Originally Posted by foremi11 View Post
I agree, but the temps i see on the mamba max after a 5 minute race are extremely hot. I don't know what it is but it just does not like my 5.5. The motor never gets above 150 in 5 minutes, and I have the timing just below average and the start power on high, but it will easily reach 180 or 190 in a race without a fan.
Hopefully the mamba pro is A LOT better with the heat, I plan on buying one, just waiting to see what the initial response is towards them.
My mamba max (was using yeah racing 60A brushless esc) dropped the temp on my yeahracing 5.5 T 6000kv motor from over 60C to 48C with higher power output (higher speed and acceleration), better response (nothing to do with settings. Max setting/reducing timing on the YR esc doesn't even compare to the MM) and the thing that amazed me is how smooth the throttle is!!! My buggy can crawl at like 2 mph with no cogging using the slotted motor. I wonder how much smoother can a sensored system get. The down side is that it seems to be running a little hot even on 2S lipo. It is supposed to be rated at 100A continuous right? I don't see how the MM can do 100A cont without any advance cooling.
