simplechamp
simplechamp's Avatar
09.06.2009, 01:54 PM
If I use an 8x12 bearing on the diff cup side and a 6x12 on the spur side it should fit in the stock trans case without any mods right? (except a little shimming)
Urgeoner did you use the JB Weld so you could have a larger bearing?
