Originally Posted by maxair45
http://www.hobbypartz.com/60p-dyc-1004.html
Also what about this one? Its a bit smaller(helps as pit space is limited at the track), same feature as the other one, usb hook up....but no feedback. How do the specs look? I like having options.
That one is still 50W but does require an external power supply.
What charger/chargers do you already own? Will this charger you want to buy be your main charger that you use?
