09.08.2009, 03:45 PM
Well, the MM has about the same rating as the HobbyWing 80 as far as the FETs go, so I would just be careful about mesh tightness. Also might help to dial in some punch control (to help reduce the huge instantaneous currents on takeoff) and add a couple extra low-ESR caps to the power leads.
And since the MM has a linear BEC, you will want to disable it (remove the red wire from the throttle cable) and use an external switching BEC.
