david lamontagn
09.09.2009, 10:19 PM
Question:
If you use the slash axles though, which are 5mm all the way along, then wont they still fit the crt.5 knuckles and bearings, allowing you to use the slash 17mm hex adaptors? Or am I missing something important?
I've think about it, but the crt.5 use universal steel drive shaft, and on the front, the drive shaft pass thrue the C-Hub, and the Traxxas slash axle is mount on the plastic slider who'll never pass thrue the C-Hub of the crt.5.
If somebody would want a 2wd crt.5, maybe it was possible, because i'am sure that the rear slider of the slash could be fit on the rear of the crt.5, but not up front
