riverat1540
riverat1540's Avatar
09.10.2009, 05:18 PM
well i sent the mamba monster in for replacement thank god for warranties, i have a used 80mm 2000kv medusa on the way and also a 1521 i plan on buying but it needs bearings. also was offered a 1527 1500kv motor but think that may be overkill. i just hope i dont burn another controller up. i think it was just all the strain from the 1515 1y trying to get up to speed under 6s. i was beating the truck pretty hard. i took some spiderwire 20lb line and wrapped 4 places on each front tire and it was soon after that it died. but with the tires not ballooning it was way harder to get the front end up at speed and was just about topping off on speed before the rears started to balloon. i need a slower motor with more torque so im drawing less amps. if i get the neu ill get bearings for it and run the medusa in a boat with a water jacket. either way the muggy is getting there.
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
