Thread: Same charger?
09.10.2009, 08:55 PM
Originally Posted by maxair45 View Post
4000 MaH 2s tops and 4s....4000MaH most likely if not less. Also is a 25a esc too little to use in a stadium truck running 2s 35c? I will ONLY be running 2s but i'm afraid that the c rating might kill it....Will a 30c or 40c 2s kill a 25a esc?
you could hook a 100c battery up to that esc, it's the motor and vehicle that determine how many amps will be pulled through the esc.
at 2s (14.8v) 25 amps is 370 watts. (14.8v x 25a = 370w)
Even an "s" can feigao can pull way more than that.
so, no, the battery won't kill that esc, but the motor and weight of the vehicle will
