aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.10.2009, 10:50 PM
also if you look at the inside can/windings of the higher quality motors.. You will notice that the windings are "tight" and "even".. Whereas if you were to look inside a cheap motor, you would find all kinds of spaces/gaps.. and after a while.. lots of corrosion on the windings itself... Some of the KB45 windings are just plain awful.. and some are good. The worst one I've seen had a gap where my pinky would fit into it, can't beleive it still ran ok...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
