09.12.2009, 08:04 PM
interesting......I looked up what you said, and it appears to be a bad heat sink connection that's causing the gpu to over heat and not the ramm?
I'm still clueless on fact of what causes 3RROD, as there are a lot of contradicting noobs out there with cheesy or dumb "fixes".....but I do have a bit of info....to reset your xbox after you've completed your 3rrod fix you must unplug the fan let it get the two red rings turn off plug the fan back in again and it should start up from there. This has been verified by several sources.
