brushlessboy16
brushlessboy16's Avatar
09.13.2009, 11:18 PM
Originally Posted by danhfvcsd View Post
Would i be right in assuming this comment came from "brushlessboy"?
When you say "cutting out" - was it turning everything off - even steering??
There is some 'part' inside of mine (at the bottom) that has come loose, and eventually stopped the esc working all together... It seems that i could press firmly on the bottom of the esc, and it would make contact with this 'part' and the esc would boot up again... but when pressure is taken away, the esc dies again...
I solved this short term yesterday on a small track i was messing on, by adding a small plastic 'block' underneath the esc, and zip tied the crap out of it to keep it held down... it worked for a while, but a few hard landings, and she was dead all together, and a i couldn't get it on again by pressing the bottom of the esc...
I know it was a long intro/explanation - but i was just wondering if this is maybe what has happened to you also?
Yeah its still got BEC, steering and all. just no power.
Ill Look at it tommorow
