09.15.2009, 08:20 AM
When you mean backwards do you mean:
1 motor rotates backwards?
2 Colors on ESC indicate throttle is acting as reverse?
If 1 then is sensorless just swap 2 motor leads, If sensored then you need to change setting on ESC to reverse motor direction
If 2 then yes reverse on radio and rebind
I would suspect 1.
