aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.17.2009, 01:20 PM
All I can say is that this thing is phenomenal. Great job.
Thanks, I'm glad I got this project done in one week.
Originally Posted by virusss View Post
Excellent work congratulations, I wanted to know how you felt about
protect the engine from dust, it has a
fan that sucks in air.
I have the same problem on my baja with a NEU 2215 and
I do not know how to fix it.
As you can see in the rear of the motor can is the intake. I will put a piece of foam or some kind of filter around that whole area. I'm actually leaning towards covering the whole motor(mount and all) in some kind of filter cloth/material. but for sure the rear will have a filter and the front sides of the motor will be shielded as well...
Originally Posted by KaztheMinotaur View Post
Check the space between the center ring and pinion. I had to shim mine.
Yeah, you are not going to have many battery mounting options that way.
Hey, thanks.. I will shim it for sure.. I'll have to figure something out for the battery mounting... Right now, I I'm thinking of mounting the battery on an angle in the rear. But I'll have to play with it, because I want it as balanced as possible for the jumps.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
