JThiessen
JThiessen's Avatar
09.17.2009, 06:58 PM
Your probably correct on the body causing lift after a certain speed. The theory of using no body to aleviate lift at those speeds would be spot on, but then you are faced with overcoming the drag. A front wing might be the key for getting the majority of the air to flow over the truck - I'd even consider one that extended beyond the wheels.
